The pro's (Ronnie/Jay in particular) don't seem to eat any tuna actually.
They eat mainly chicken, Jay has 1 red meat meal a day, and usually fish or sushi once a day (keeping in mind he eats around 10-12 meals a day)
Then before a comp he switches solely to fish...Less fat and thins the skin for a tighter look.
Ronnie is a bit more loose, eats grits with cheese instead of oats for breakfast, mixed with his egg whites, from Eggology of course.
The rest of his meals are usually chicken, baked potato, chilli cheese fries and corn bread...Good ole' corn bread.
Chilli cheese fries sounds good
Sounds unhealthy but I'm assuming its healthy. Where do I get some mang?
just bought 60cans of safcol yellowfin tuna in oil
fucken better taste good lol
Not a fan!
Go to Misty's Diner in Prahran...all American food, you can get chilli con carne fries and they are the bomb. Don't forget to put death sauce on top.
And deep fried cheese sticks...
Cheers mang,
Saved me $2,000 in flights and accomodation
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
