Your a badass Alvin
Do you do it in style like Nicholas Cage?
VX Pro Gas baby
No. We find somewhere to hide
sandbag sandbag sandbag sandbag + 2 explosive blocks, we call them block3s. set up the detonator, set up the detcord, run to hiding spot, at least 50m, behind cover, and press the button!! Nothing fancy, just a button that detonates the detcord. The detcord sends a detonation wave to the block3s,
BOOM. exercise cut!
you can stagger the detonation order by varying the length of the detcord, i can't remember the rate of burning now though. been ages..
sandbag sandbag sandbag sandbag + 2 tnt blocks, set up the detonator, set up the detcord, run to hiding spot, at least 50m, behind cover, and press the button!! Nothing fancy, just a button that detonates the detcord.
BOOM. exercise cut!
people get sent to jail for this shit you know
Might have been Smarties.
But M&Ms are so much better. Just sayin.
skittles are better. taste the rainbow
yous
yous
yous
yous
yous
yous
yous
yous
Are you from Frankston?
hahahahahahahahahahahahaha
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
