Rofl. Signed into iTunes. Same problem. I'll try mums card when I get home.
just ask yourself. do you really need that game/app your about to purchase?
maybe you should put that 99c to charity.
I was reading the SAU facebook wall last night. And thought gee whiz, shit just got serious.
Have you read the stuff he has posted on his own facebook wall? Kris and Alvin getting called out LOL
i havnt seen the facebook wall could you link it?
i have read the stuff he has posted on his twitter and shit calling out Kris and Alvin :P
YA RLY.
Oh well, like i've put forward plainly, one does not provoke people to "come at me bro" and then when people actually do, one should withdraw his/her right to whinge and sook about security being lax. How about taking some responsibility mang.
I wanted to go all out but vice prez brah'll get youmadness
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
