come live in knox and say that :P
Mr.P is training up all his minions in rowville and knox. Two TMU stations to deal with now ~_~
i wouldnt care, you have your car for fun
if your going to be pulled over whether you car is stock or modded you can still cop the epa so just drive it with mods and enjoy it
I have a stock turbo :(
mines stock from another model
Just found out that:
- Someone is taking my grandad to court for a car accident after hitting my grandad from behind. No marks from the accident so both parties agreed to do nothing.
- Fast forward to today and now he wants money and is bring lawyers into it. And is also taking it to court
- Funny thing is letters show $3,000 of damage to the front of his car.
- Even funnier is that the 1st lawyer documents shows the other person car as a Alfa Romeo with 'x' rego then the 2nd request shows a white van with 'y' rego with $3,000 of damage.
All seems sus and wouldnt be surprised if they though becuase they smashed into an old guy they will take advantage of him. Going to do some investigating tomorrow and hopefully rip the other party a new one.
/csb bro
go ahead with the court thing then topsy turvy that mthrfkr and demand he pays for your/your grandad's day taken off from "work"
I will topsy turvy the M*therfker like no tomorrow. Will call the lawyers and magistrates to make sure the letters are legit. Then call the insurance company to let them know of the full story
Will also call the company he works for tomororw for kicks. As the 2nd invoice shows that its a company car.
Also that looks hella mexican Billy :thumbsup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
