what determines the difference between major/minor?
or is it how they feel
Might be how they feel?
I got a major defect for being too low. The lowest point of my exhaust was 5mm off the required 100mm.
Had to get a RWC and spend $500 fixing shit up that other workshops reckon didn't need fixing....
Forever my car now will be a 4wd and I will not lower it...
From memory there is a box on the sheet where they mark it as minor or major and I think most officers will do major if there is a few items that need attention. When I got done for HID it was minor...assuming a sensible officer, major would only apply to things like a serious safety hazard or numerous engine modifications.
Cheers guys!
Yeah when my friend was taking out all the shit to get to the sparkies he kept on saying luckily I have this tool, otherwise if you did this yourself at home it would be a bitch for you to get 'x' screw out.
I get jelly when I hear my friend changes his spark plugs in his s15 in 5 mins.
You could change the spark plugs in my Calibra in 5 mins. East-west engine, with spark leads that just pull straight off the plugs...and there they are. Unscrew old, screw in the new.
I believe it is the third note.
Driven past any Highway patrol cars yet Aaron? :D
yep.
yesterday night.. didnt even look
3 days prior.. who actually put the window down and said "nice car.. good to see you not drive like a dickhead"
theres nothing to defect in my car now since i put a return flow intercooler in.. it wouldve been the only thing..
110mm high at the lowest point.
none of this HID stuff.
wheels sit flush with no poke..
i dont think engine shock braces are defective. or colour lol.
maybe exhaust is a little loud but that doesnt worry me. im changing that soon lol
that said.. i dont exactly expose myself. drive to work and back. sometimes, or to the missus house.. otherwise she drives her mobile.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
