oh well hes a silly bugger anyway, everybody knows you slow down before the bend on that road :ninja:
1. The speed limit drops to 80
2. Theres a retirement village
3. The cops always sit there waiting for people that dont slow down..
No tony if its over a certain amt of kms they will crush it on first offence...
Really? That's quite gay.
So if someone was having fun on a freeway in his/her Lambo, then it would essentially be a $500,000 fine.
That shit is messed up. Penalty v Crime does not weight up. You'd be better off getting thrills bashing innocent people on the street.
thats just the way it is, things will never be the same.
Yeah that's the place, was fun with 302rwkw GTR, and had couple of frights by the constabulary...
yeah the old roundabout was good you could really nail it through..the new ones alot bigger and its not that it slows you down alot but you dont have the same momentum coming out of it.
So where the old one you would slingshot out of, the new one you have to power out of, kind of killed the fun of it....
Is that the round-about with a BP and Macca's on it?
If so, nice long flat straight indeed....
Nah that's on Dandenong-Hastings rd from memory. The road Arthur and I were talking about is on Frankston-Dandenong.
nah thats western port hwy..frankston dandy rd is the next one over.. There is nothing on it but a few old farm houses an old helicopterand a cemetry..
did you know that tupac copied that song..i noly hheard the original the other day on some AM radio station
well not really because im pretty sure it was produced after he died..lol
they used a lot of old music for his chorus' after his death
yeah heading north through thompsons rd roundabout theres a nice stretch where '(dare i say it) its safe to open it up a little..but some silly buggers forget to slow down
haha i lived around there for 6 months, that was a nice little stretch
looks like some bloke was late for work on frankston dandy road this morining, now hes getting his nice new EVO..
iMPOUNDED..
Pretty funny it was too low and they couldnt get it on the tow truck..what speed would you be doing to get an on the spot impound?
i saw cops hanging around there at 8 every morning thank god i dont go that way to work anymore
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
