That's if you don't count today or Friday, = 3 days.
Btw, for sale, single bed from Friday to Sunday.
Goulburn valleys motor village. $60 dorra
might be interested ..why you not staying
good work man. doesnt it ive you reason to just leave it and avoid problems? lol
Yes and no! It will be higher than it was for track purpose... 2-way, exhaust, steering wheel are all going back in this week
At the moment it sits as high as Alex's car haha
Not really.
Was curious cause if you do lower your 34, it really shouldn't sit that low and it'll well within legal height.
The problem with my car is that the exhaust its really low. Came like that from the land of the rising sun.
At the moment I would say the gap between the tyre and guard is about 5cm just to clear the 100mm clearance....
Change your exhaust brah.
Sell your current exhaust and give or take $100, get a better fitting exhaust.
Have thought about it, but don't want to spend anymore on the car than I have to I guess. Also was getting pretty bad wear on the inside on the tyre when it was lowered and is my daily driver.
At one stage I be mirin those racepace exhausts. Then I saw the price tag and cried.
I feel you meng.. but not in a priest way
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
