Relatively cars are cheap if u finance it live at home etc what's 1-1.5k a month if u work full time live at home ? I mean that would easily get you a 60-85k car
finance approvals would be hard for 85k on a basic collections salary of 38k a year.
Ordered - Nismo low temp thermostat, greddy oil filter - Who wants to help me install oil filter relocation kit and oil cooler? anyone?
I will if ya can help me undo my Coilovers collars and get my car sitting right
VE Maloo is what, 60-ish k? Combine it on 18/9y.o. Apprentice, obviously leased thru father or immediate family member as it's high unlikely that any boss would happily give apprentices this kind of car.
yeh, or it could just be their dads car.
I don't even have a girlfriend lol
I'm sure your still smashing boxes on the weekend
what do chemical engineers make fresh out of uni? if i'm willing to work in outerspacey areas.
I share a floor with engineers, not chemical ones though. Can ask if you want.
Asked a fellow engineer he said
~50K if you work at a small company
80K plus if you are at a big one at the mines.
Time to move to Perth yo! Can afford a R35 GTR in no time
I will rape you if i get a chance
Been distributing some serious gas right now stinking up the whole joint..
Want insurance moneys? Lit when you fart next...
@alvin, average for chemengo grad is 56k.
Obviously sky rockets after a few years experience.
will so move to perth.
I honestly have some gas problems for the past few months now. I produce allot of gas and they tend to escape unexpectedly at any time.. gets a little awkward when a customer has a whiff at it and i bolt from my standing position to go open the door..
Def seeing a doc tonight lol
hm. been eating properly? sounds like you're having some gut bacterial issues.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
