lol @ hearse cruise just don't show ya pussy scared of some keyboard flamage?
You'll feel out of place if u don't attend with the wasteland crew.. Almost need something to identify the cool cats
On seats I like my bride and for $600 second hand in immaculate condition good value to
I wanted to, atleast for sunday.. but theres a stagea cruise, and i kind of said I was going lol i tried to make it a cruise to the sns, but they wont listen lol
thats why you should have made it 6th and you organised it so who is to blame
you kunts have to back me up lol
http://www.skylinesaustralia.com/forums/topic/381137-vic-stagea-cruise-plan/page__st__20__gopid__6082346#entry6082346
Mick, it had to be the date with most votes. lol unfortunately out of my control.
BP Petrol Station on Warrigal Road.
Just off the Monash freeway near Chadstone. 6:25-6:35am
Join your fellow wastelanders.
dont do the BP. harvey norman just up the road has more room and is less busy at that time. thats where all the GOR cruises used to leave from (eastside premeets anyway)
I did think about and did mention that, becuase I have been there and it is quite small.
But the other guy wanted to and I think there won't be that many cars there at 6:30a.m on a Sunday morning. And there should only be a few of us.
Plus the cars can fill up on Petrol and wash their cars there if they want.
SHouldn't be busy, who wakes up that early on a Sunday morning on a semi long weekend :unsure:
what time is everyone leaving then? and its raining.. not much point in washing lol i might just attack mine with a pressure hose.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
