No call yet, I'll go to my local cop shop if I haven't heard anything by next week and look into pressing charges so the cocksucker loses his job
you got rammed by the truck or something yeh?
thats f**ked
Cops didn't tell me the name of the company and I only got the rego, couldn't make out the company name on the door as it was only small and the rest of the truck and trailer was plain white...
All I know is it's a company in the sticks...Druin or something?
Never really heard of the place, but I guess if it's small enough it wouldn't be too hard to track the company down. If I can do that then I'll definitely call but I wouldn't expect some freight company in the sticks to have a HR department..
http://www.truelocal.com.au/find/freight-transport/vic/gippsland/drouin/
If it's any of those I'd say it'd be 1 of the first 2, wasn't a cattle truck and wasn't a flat bed which would more than likely be the trailer choice of a crane delivery company...
The fact that they're businesses in bumf**k nowhere means they have no websites (that I could find anyway) so no chance of seeing a picture of their trucks/logos
Do you know the guys name? Will be easy to confirm the company he works for.
I.e. If it's company number 1.
Get someone to call up 'Can I speak to John Sanders' please?. If yes hang up.
Call back in 5 mins. Speak to HR, if there is none, speak to the Directors/Bosses or managers.
Touche'
But thought you chased the truck till he stopped so woulda thought you'd ask to see his licence to get his details etc..
Or did you just pull over after it happened cuz your car was busted lol?
Touche'
My car was fine...I pulled off the exit ramp coz it looked like he had finally come to his senses and was pulling over, as I did that he went straight through the lights and back onto the freeway..I was already on the phone to the cops by then
If I did get him to stop, I wouldn't have been asking to see his license, I would've taken it out of his pocket after I KO'd the flamin mongrel though.
Seriously can't even begin to describe how angry I was... and that's without steroids.
what car were you in?
My EA...Bull bar on tow bar is the only reason there's no damage...Haven't checked if the bull bar has been pushed in or whatever, doubt it but that'd be the only damage if there was any.
My brother has been talking to a cop mate of his, makes me wanna fucking smash that cunt of a cop as well...They're all stupid cunts
'Is there any damage to your brothers car? If not they must not have collided. Obviously at speed there would be evidence of a collision, paint etc'
So basically you're allowed to go out and ram whoever the f**k you want, just don't do it hard enough to cause any damage or leave any paint and your in the clear. Or slap on an unpainted bull bar, smack a car with a tow bar and you're set.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
