How much power you got Danielle?
You car sounds tuff and looks quick
Not enough...but is it ever?? Hehe
It's all noise lol but thanks sooo many nice cars out for s&s makes my $3500 crappa look bad :)
well deserved too had a chat to him and there is some valuable shit on that car.
good guy too. no homo
Did anyone else take a look under the car, I think he ticked almost every box from the Ikea Formula catalog.
Never knew a Swedish big blue store that sells the fancy chair I'm sitting on sells suspension arms.
no shit. he was telling me what was next and explaining every aspect of it and why.. he knows his shit.. not like one of those guys who say "broi iz it turbz duz eet dose"
oh n thanks for letting me sit in your car.. sorry for causing a rukus outside of it.. and giving moh intentions of breaking your bolsters lol
haha not sure how i ended up leading the cruise, wasnt exactly sure where i was going. Google maps saved the day!
The blue car has as much rights on the road as we do however common courtesy would be for him pull over if he wants to drive 40km/h through a 60km/80km zone.
Decided to just slalom behind him and I saw you doing it too in my rear view mirror haha. I wonder if it went down the chain of cars :P
Let me rephrase my comments, what I meant was that it was classified more as a race car (and i think it took the award for that too) than a show'n'shine winner. I would put my dollar on Sunkist as his s14 was more presentable in paintwork, wheels and overall exterior.
Ah yeh fair enough makes sense :)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
