Yep, hasn't been up on carsales for long but not really getting any hits on any of the sites its on at the moment.
Hmm... Considering selling the GTR soon-ish but not sure if I'd have the patience to wait for long time.
If I had the choice I wouldn't sell at this time because I know I'll probably only sell it for 10 if I'm lucky, only selling cos I need that money for other things but we'll see how it goes I suppose.
I suppose I'll have to wait until I get an apprenticeship or not and go from there.
does anyone else find it impossible to go through twisty roads as passenger and not get badly sick? sunday night was throwing up from 10pm-5am to the point were just blood was coming out...
head's been spinning for the last 3 days
i should've just come to this nats thing
lean into the turns. you do this while driving, which is why drivers never get carsick. passengers tend to passively get leant outwards. the constant sideways G forces confuse your inner ear. leaning into the turns counteracts this. never get carsick again
lol what
Are you positively annoyed friend?
did that for a bit then got over it. soon as i start moving my head, look down etc = f**ked
That thing competed on track day. Not bad.
is it an m3? e36 > e46 for track
went through 125 pics/125 gay comments left by a Justin Gould wtf...
Lol his just a clown
Also in regards to Borci selling the Gts-t. Price it to sell now, otherwise you'll be forever lowering the price.
how much grant
I took 20k flat for mine, hard market out there.. Unless you got a track spec 33 GTR then IMO 25k-30k (mine was advertised for 22)
You should get one!
I must admit though tempted to buy a s14 or r32 or something just for track, cheaper and still a shit load of fun for a dedicated track car :D
Couldn't agree more, always gonna be dropped especially with a skyline may as well start it off low rather then try selling it for 6 months, pay insurance and rego in mean time + fuel etc = big fail.
Yup...
great price for 12/10k. Was searching for a r33 gtst for my friend. Couldnt find anything clean and around that price. He's since purchased another car now so cant help. :(
Yeah definitely, I'll probably drop it to 11 in the next week and see if I can get some bites. It's just a shame there isn't a WTB site you can go on where there's 30 people who want a skyline for 9k and u can just drop in and offer them all and see who takes, rather than wait months for that right person to find it on the net.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
