Seen a few episodes of Jersey Shore for the lulz
i find that shit hilarious.
the two fat dirty looking girls are f**ked
the bohemath guy is always angry
and sonic the hedghog who constantly starts fights lol
Dudes in USA why u postin here get out there probably sitting in a room on the internt the whole time
Gotta stop biting my tongue..
Was gonna say, on holiday in America posting daily updates on social economics, and I'm the one without a personality....
