20 years doesn't mean 20 years to develop a more powerful engine, there's more to it than that. Any manufacturer, even Daihatsu could put a 220kw N/A 2 litre engine in the thing if they really wanted to, but it means more money on production costs and less fuel efficiency. But try passing in the RB20DET under today's emission standards and you would be laughed at!
And for that matter, 20 years prior to the R32 GTS-T was the TA22 GT which weighed in at around 900kg and made 93kw from a 1.6 litre N/A engine...
I think you'll find this car to be positioned with similar performance to other sports cars within similar price ranges. They may also be making space for more powerful versions of the engine down the track, giving marketing something to keep pushing the product.
I know an rb20 would pass emissions the s15 in 1999 didn't even pass American emission standards hense why they never got it
I just expect a 'sports' car to have a little more power
really just depends on the price if the ft86 is around $30k for the na model as people have been quoting then, it will be decent but if it's closer to $60k, I don't see why you wouldnt just spring for a 370z or skyline v series
im a limo driver tomorrow daytime for stakes day or whatever it is.. gonna be cruising around in a 300c lol.
sat night im free though.. pm me your number and i'll cruise up with you if Ive got time.
I was more asking where are you taking the Stagea boys this weekend don't you have a cruise on?
Your a banker/Audto guy and a limo driver. Shit is full on bro
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
