20 years doesn't mean 20 years to develop a more powerful engine, there's more to it than that. Any manufacturer, even Daihatsu could put a 220kw N/A 2 litre engine in the thing if they really wanted to, but it means more money on production costs and less fuel efficiency. But try passing in the RB20DET under today's emission standards and you would be laughed at!
And for that matter, 20 years prior to the R32 GTS-T was the TA22 GT which weighed in at around 900kg and made 93kw from a 1.6 litre N/A engine...
I think you'll find this car to be positioned with similar performance to other sports cars within similar price ranges. They may also be making space for more powerful versions of the engine down the track, giving marketing something to keep pushing the product.
I know an rb20 would pass emissions the s15 in 1999 didn't even pass American emission standards hense why they never got it
I just expect a 'sports' car to have a little more power
really just depends on the price if the ft86 is around $30k for the na model as people have been quoting then, it will be decent but if it's closer to $60k, I don't see why you wouldnt just spring for a 370z or skyline v series
im a limo driver tomorrow daytime for stakes day or whatever it is.. gonna be cruising around in a 300c lol.
sat night im free though.. pm me your number and i'll cruise up with you if Ive got time.
I was more asking where are you taking the Stagea boys this weekend don't you have a cruise on?
Your a banker/Audto guy and a limo driver. Shit is full on bro
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
