do it yourself
its pretty easy
theres even howto's in the howto section on it
the paint costs about $40 tops and some shitty sandpaper
to do the writing differnt colour paint the calipers one colour with vasoline over the lettering
then when its dried and done, wipe the vas off and reverse to do the lettering
Grad accountant who I extended the probation period for has spent 1/2 and hour trying to open a file but couldn't and is asking me why.
All she need to do was to unzip and extract the file
An accounts girl we employed doesn't know how to use Excel...fark.
If I got given that... Sell it, buy s2k = 50k+ to play with
I think I know the owner of that, if it is then her dad works for Porsche Australia and had it de-tuned so she could legally drive it on her Ps.... What an 18th present though :rolleyes:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
