how does an asian, not know about bit torrent?
hahahahaha lol soooo true
My brother used to do all that, and I'd just leech all his stuff.
Now after a while since I've moved out, figured I need some new stuff :D
Yep brain dead yet worth more than you'll ever be.
Lifes a bitch chump.
Keep trying to be some cool Internet guy I know for fact your a deadset loser in real life so pretend all you want only person failing at life stares right back at ya in the mirror.
Just so you know I'd run rings around you in any capacity however you aren't worth my time or effort so cheap insults work for me ya fugly fat mofo :)
Honestly Just give up and accept your nothing but a scrub.
lol birds well played.
You can have all the money in the world yet as a person, you haven't developed an inch, if any. You're still bitter on what has been said and done, have personal grudges on an internet forum as you seem to take this shit too seriously coz in your own world, internet is serious business ye? You need to snap out of this high school mentality you've been carrying most part of your life, i suppose people don't understand why you would risk venturing into the unknown when you could just comfortably exist with the current conditions.
no you dont. old stuff is better.
True, but all old shit has been lost with computers dying, and car cd's now all scratched to the shit..
Or you can help a brudda out and make me a car cd mix? :D
lol you have no idea, really none at all. You troll the internet for fun and think I'm the one with issues..
You take a holiday by yourself and spend your time posting on the internet.. Even more laughable it's not like your keeping friends updated your telling a forum who thinks your a Fkn dip shit that nobody likes why not call a random number and start telling them they might actually care slightly more than anyone here
Keep crapping on trying in vain to prove your better than me all your doing is confirming what everyone knows already about you.
yeh if you want. pass me hard drive and ill fill it up with what I can if you like.. you only live in mulgrave so not far.
Let your butthurt speak out and keep up the tall poppy syndrome my son, showing strong signs of conflict between the desire to be noticed and the fear of being humiliated.. it's plain obvious that im arguing with an imbecile that has an iq below room temperature :no:
Cheers mang, can offer movies in return.
You going to the cruise Friday night? I might go depending on a friends personal situation.
Might organise a SE pre-meet as I know another 5-9 cars that might come.
dunno if can be assed driving to westside.. let me know if your definitely going and ill see. I have a lot of driving to do that weekend as it is.. and the clutch is effd from arthurs seat so that getting fixed at sabaddin coz birds cant fit me in this week..
we'll see what happens bro
and yeh.. need some movies.. just no home made pornos of yourself lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
