he puts himself out there.. in the light with the footy show and all that, do you think the show would be remotely any good without him?
agree with ric. push the limits you get results
no doubt but look at his car, like what 700k? plus a boat probably a couple mil, penthouse apartment at docklands.. i mean how well could the footy show pay?
having said that garry lyon was looking at buying an 8-9 million dollar property :whistling:
