Alex,
Buy new FG MkII GS Black, 50k-ish
Stage 1 (Tune and filter - 435kw):
$2694.00 Including Factory Warranty Protection* / $1744.00 Excluding Warranty
http://www.kpmauto.com/tabid/417/Default.aspx
KPM sticker kit is $500 (imo yellow looks sweet), Black 20x10s ???
Thinking about going that route now instead of GT, which are like 65ish for a demo.
Yep, and do brakes later down the track also in yellow (those are harrop) but can always respray red brembos.
Probably powder coat stock rims matt black, to save some $$$$ initially as well if I'm going for that look. Which imo looks BAWS.
Might check this one out:
http://www.carsales.com.au/demo/details/fpv-gs-2010-11304388?cr=33&distance=25&vertical=Car&eapi=2&Page=3&sort=~Price&__N=1216%201246%201247%201252%201282%204294965879%204294966800&silo=Stock&Range=Price:40000,Max~1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
