needs to extend all the way to the edges, looks weird being just down the middle..
I should get my whole car wrapped to cover the f**ked paint....hmmmm
that was a tricky one. As the roof is seamless from the roof panel to the rear quarters etc if you extended it you would see the sticker edge. I cut the vinyl to sit in between the roof edges which hides the edge of the vinyl.
people would charge a lot because its a fiddly job. Always have to pull it back if you have a bubble or a crease. You will pick up any imperfections real easily on a flat colour vinyl. Easier for panel beaters to spray and rub back/cut to fix any probs. Cant do that with vinyl.
