Still more than likely to go for my license in march, then buy bike at some stage after that. They'll be cheaper as the warmer weather fades away.
Black (if I find one in black at the right price/condition etc) ninja to start, but eventually it'll be an all black gixxer
I can still dig your previous posts just few months ago asking why anyone would purchase a bike..
You were vehemently against it.. why the sudden change of heart jelly bean
he was asking why anyone would buy a bike despite the dangers, riding in the rain etc. it was because he's been wanting a bike for a long time and wanted to hear if the pros outweighed the cons. context, you have none
what do people think of these rims
Work LeadSlead 17x8 +5, 17x9 +/-0
if i had a hot rod it is definitely something i'd buy, they are multi-stud too 4/5x114.3
not on a jap car imo. great on hotrods, maybe even some euros (golf etc)
Niroj it's a shame to see you join his clan of sidekicks as well.. :rolleyes:
im in no one's clan mate. just stating the facts. long story short, im sure you are an ok person irl, but your posts are 99.9% absolute drivel. 0.1% good stuff sure, but its not enough to make me like the persona you project online. cheers.gif
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
