I missed Leigh's 2nd run cos of the stripper pic you sent Tony.
Might be a good thing not to watch Leigh's fancy ford putting a better time than I did with the R.
Calder was pretty crap last night, got there at like 7 and only got 2 runs until 12.. (with a small dinner break).. around 300 cars there. First run was complete shait, left it in full auto performance mode with traction control off and span 1st 2nd 3rd off the line drifting next to the wall with a 2.7 60ft just let off.. 2nd run was a bit better 13.2 but hit limiter in 1st to 2nd which would of cost me that 12.
Until next time! will definitely be heathcote though. Less cars ftw. Probably enter in that tri battle thing - Ash you going??
Also met Grant down there in his R with a slipping clutch from looks of things :P
Mph?
Mph?
108 on the only half decent run, 92 cruisin my 17 sec quarter after I mc'royally f**ked the start
Just finished cleaning some of the rubber off the car, decent amount came off the tyres for just 2 2nd gear burnouts
I did 109.71 on my 2nd run.
Is that the tri-club battle thing? Might get my entry in soon. Hoping for a 115mph
Shouldn't be hard my GTR only had 233 rwkw at the time and couldnt go any faster than 111 cos of speed limiter lol.
Get your entry in brah I did mine today
Ye Calder in all honesty is NOT the place to go to test/tune. Really need to drive to Heathcote these days.
Calder is just toooooo busy :(
I'm waiting for Snowman to get back from Bali. If he says we are doing Mt Baw Baw Sprint - then I won't be...
If I don't do Baw Baw then 100% be @ drag challenge :)
Yeah, waited almost a hour for a run, and bikes get more runs than we do with cars...
Farkin this...there's that magic (or not so) age in your twenties where you just can't do it anymore lol. When I was at uni I could go out on a thursday night and be at uni the next day on 4 hours sleep. Anything less than 8 these days and I feel like ass!
The majority anyway, I know some my age that can happily pull all-nighters nearly every day of the week. I think I stopped being able to do that at about 22.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
