you probably got water in your air filter brah
lol alex was waiting for someone to say that
I always leave it to dry for halfa before I start it after washing. Not a good idea to do it while it's wet. You probably went a bit overboard with the hosing too :/
Rimon, you could have wet some of the electrics, should start again once it's dried out. Try to avoid too much hosing from above the base of the fuel tank.
i did go a bit nuts with the hose....
i'll try starting it again later
Bullshit asshole nobody likes the new format here
I actually like it.
But then i've been using it for quite a while longer than you guys.
Functionality, once the minor bugs are fixed (missing buttons, emoticons, maybe drop the default font 1 size) - It'll come up nice.
From admin point of view this will fix a HEAP of the timeouts people were getting when posting (that was a MOST annoying prick)
This is the last time we are upgrading for a few years hopefully as the last version just had to many problems to fix.
So all development will be based on this current design so we can enhance and alter to suit.
Hence if you post in the feedback with decent ideas & suggestions - we will see if it can be done.
That said we will probably need to bring back subscriptions as a devloper will build a new skin for us no worries - BUT it'll cost at least $600 each time so we've gotta go in knowing exactly what we want.
I actually like it.
It'll come up nice.
fkn hipster
Alright.. Good weather Sunday too.. I'm up for a cruise cruise, not twisties stuff
Hmmm just been told that even though I'm dropping the bike off on Sat it won't get worked on til Monday so :(
Drop it off Monday
Cruise
Profit?
Am I doin it right?
Tis a nice idea but only time gf is free to drop it off with me will be Sat. If anything changes I'll let yas know.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
