you probably got water in your air filter brah
lol alex was waiting for someone to say that
I always leave it to dry for halfa before I start it after washing. Not a good idea to do it while it's wet. You probably went a bit overboard with the hosing too :/
Rimon, you could have wet some of the electrics, should start again once it's dried out. Try to avoid too much hosing from above the base of the fuel tank.
i did go a bit nuts with the hose....
i'll try starting it again later
Bullshit asshole nobody likes the new format here
I actually like it.
But then i've been using it for quite a while longer than you guys.
Functionality, once the minor bugs are fixed (missing buttons, emoticons, maybe drop the default font 1 size) - It'll come up nice.
From admin point of view this will fix a HEAP of the timeouts people were getting when posting (that was a MOST annoying prick)
This is the last time we are upgrading for a few years hopefully as the last version just had to many problems to fix.
So all development will be based on this current design so we can enhance and alter to suit.
Hence if you post in the feedback with decent ideas & suggestions - we will see if it can be done.
That said we will probably need to bring back subscriptions as a devloper will build a new skin for us no worries - BUT it'll cost at least $600 each time so we've gotta go in knowing exactly what we want.
I actually like it.
It'll come up nice.
fkn hipster
Alright.. Good weather Sunday too.. I'm up for a cruise cruise, not twisties stuff
Hmmm just been told that even though I'm dropping the bike off on Sat it won't get worked on til Monday so :(
Drop it off Monday
Cruise
Profit?
Am I doin it right?
Tis a nice idea but only time gf is free to drop it off with me will be Sat. If anything changes I'll let yas know.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
