Throttle crew on Facebook, I'll be there with 2 mates if the weather is as forecast. You want the deets?
Yeah chuck em my way, if it's not too early I'll come down. Don't want a big ride though so I'd prolly just do Sorrento and visit the grandparents on the way back.
No stress Leigh.
No stress Leigh.
11:15am meet at BP marina petrol station on beach road st Kilda, 11:45 departure
