How's Nissansilvia.com Aaron?
Pretty sure i'm forever banned lol
haha i dont think ive been on it since then. they're a bunch of idiots
lol to be honest I didn't think it was that difficult to figure out, look at the context of people using the meme...whenever people are pissed off about something. It was pretty funny while you weren't understanding it though ;)
We still riding tonight, Leigh? Where you wanna head? I can't go offroad lol...
well i dont go on 9gag or whatever its called
the P plate law review certainly proves 1 thing...
The only people that seem to be able to understand the new laws about turbo cars, are the ones already legally allowed to drive them
THE
CAR
HAS
TO
HAVE
THE
VIN
PLATE
STAMPED
WITH
AN
EXEMPTION
YOU
ARE
NOT
ALLOWED
TO
DRIVE
A
20
YEAR
OLD
JAPANESE
TURBO
POWERED
VEHICLE
I already knew that. Saw it on vic roads site. Lol. A guy can't dream?
Still sticking with my B18C+T civic plan.
Turbo vteeeeeeeeeeeeeec
Still hoping VicRoads follows what QLD just did. and just do a blanket p:w on all cars.
Speaking about VTEC's
Apparently my mate is building the engines for TODA racing.
Apparently that means something to the VTEC boys
As much as it means to Toyota / Nissan / Mazda / Mitsubishi / Subaru / Suzuki and Ferrari boys too.
Me no know
I was ^unaware of TODA before today :/
They specialise in making pistons / cam shafts / timing belts / head gaskets / injection / flywheel / gearbox / exhaust manifolds / suspension.
But concentrate mostly on Honda / Toyota / Ferrari.
I just checked their cars, and Hector's gonna be running three Honda Civics with Tony's mate engines.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
