All round 20% brah? Looks good! (Also, I was considering an EK hatch for the longest time! Or a EJ8 (as EM1's out of price range). Then went out and checked some bb6's instead, since they're mad. Was so close to buying one. ... then yeah. Bought a skyline. LOLOL).
Thinking I should keep it legal (35%) on each side window + rear... but then 20% or something on the rear quarters (and pass it off as privacy glass... I wish mine just came with that sigh!)
Yeah that's why i was thinking of keeping the doors legal. and then the quarters let less light in = darker interior = makes 35% window even more effective?! :P.
So many things to do, so little time and $$.
Sometimes I wish I had purchased the BB6 though. Leather, cruise control, already had sound system, less insurance, similar/less petrol, dohc vtak...
Yeah sometimes I wonder why bought the skyrine! But then there are funtimes in the line and everything is forgotten. Until I remember ^those things that are missing... xD. Rinse, repeat.
Was drizzling on way to/from work around 12-5 if that helps. But looked like some harder rain before that
Edited by kaitoukid
BB6 was the whole package imo. But dat ass was ugly. And it was so hard to find a manual one in good cond.
550-600kms to a 40L tank. Come at me :P
Kinda glad I settled with a civic. Cheap cheap. Getting closer and closer to a go kart too :D
Haha, you start warming up to it! My mate has one, I learnt a fair bit of manual in it, so nice! Although his is quite modded. I didn't even go inspect unless they were manual brahs.
Don't have to dig it in :(. Could even deal with this crappy economy if my car was at least turbo, at least it'd be somewhat quick! If even after all this my car makes me smile, well then, if I could have a turbo one... life would be so good :(. Then I think of selling, and joining the trend of not owning a skyline xD. But then I'm like... hmm... time to throw some money (i.e. exhaust, sound) zzz.
Keep it man, you'll probably regret selling it. Haha.
Civics are fairly overpriced for what it is. Fairly reliable if you find a good example (pleanty out there) they will last forever. Parts are real easy to find. probably the most supported car out there (iunno how to explain it, but nearly every part is readily available, new or second hand) wreckers, ebay and ozhonda.
But i'd just go for an excel if you wanted just a car. Haha
Blue came with the bike. Might get red down the track for a change but I've seen it before on R1s and it looks a little tacky + slightly more illegal than blue.
why not get xenon white, they look good... ask Jonoe I gave him some parkers for his civic
1000-1200 to a 55litre tank, Are you positively annoyed friend?
Amateur...
5%
Can you even see at night! Bahaha
More or less where I always end up haha. Just end up accepting the cold facts :P.
GTI you have? (i think?). So gewd. Jelly.
Lol as for sliding... *looks outside at weather* :whistling: ...
Edited by kaitoukid
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
