I remember this bday...I bailed :(
Fk your bday, just have me round for dinner and introduce me as Jess' replacement because you're finally coming out of the closet - would be hilarious no?
Agree with homestyle, always going to be better than all but the best restaurants. My mother is a ridiculously good cook - not just because of who she is, but other people tell me this.
haha i could imagine if they believed it aswell..
yeh.. its the same thing here, all my mates and relo's that have eaten my parents cooking love it.. people that cant even take the heat will still go for seconds.. especially mauritians man, those dream boats go red n sweaty lol
can we push it to sunday? duck party!!
eh. i have to work on sat LOL. boss said 2 girls have taken sat off so i couldnt. minds a little foggy too. no idea how i'm going to do friday's paper.
can't Sunday picking parents up from airport
will organise for few weeks time
I've been once or twice and wasn't the biggest fan, but that might be due to me going on non-peak times so not as fresh as it could be.
There used to be a Rich Maha in the city off Collins street which I used to go to quite regulary during lunch, I always thought the food there was quite good.
same people. used to have a joint near williams too. i think they've sold both the cbd joints
its not my shit, my mum and dads shit.. fkn good!
the thing with restaurants is that majority of them make shit in bulk and its all commercialised recipe's i haven't come across many places that taste anything as good as home made(with standards) havnt been to RM so dunno bout there but yeh..and im sure Niroj will back me up(unless he's indian which i doubt - dream boats blacker than night) Sri Lankan styled cooking is f**king ten times better than indian.
sif think im indian. i shower regularly. in fact i had one last month :P. nah nothing as good as home made, nor anywhere near as hot, but its decent stuff. the cook does malaysian, indian and lankan. does the first two better though.
must not be that good then :P
would be nice if i was actually trained as a chef, and not self taught.
lol. the only training i got was as a teppanyaki performer. meh.
tepanyaki is still pretty good training..
to me it was a waste.. i never actually worked in the industry for more than a month.. i dont know how hamish did it for so long.
Alv - now that you're an eastern suburbs kid, have you tried Rich Mahas yet? I know it looks like shit, but this beef curry is decent and there's no better roti in Melbourne.
Prolly should have instagrammed that or something, clear images don't do it any favours lol.
Have you eaten every available roti in Melbourne to make such an outrageous statement?
tell me about it.... :/
on the + side I cook baller meals at home now lol
haha i was soo thinking the same
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
