New cars won't come out with black lights I don't reckon. Chrome tail lights is kind of the style with cars that have good fuel efficiency, and carbon neutral, which probably is the explanation behind it
notsureifsrs
Very serious, Prius Camry all of them a chromies. Even the aurion
I would think its more of a Toyota general styling cue.
But hey if I'm wrong and chrome tailights are supposed to be a representation of fuel efficient/carbonn neutral cars I'll shout you a beer at the next meet :P
Huh? Chrome started with the Lexus Altezza...from there it grew into a massive aftermarket of chrome tail lights for other makes and models, then the other manufacturers responded to the trend by beating customers to the chase (Holden dealers sell chevy badges now) and fitting them to their "sporty" hatches and mid sized cars etc. Don't know where the green connection is :/
I always thought of it as a connection. I don't see the 370z with chrome, where as all the fuel efficient/greenies seem to.. I don't know maybe just my observation but keep an eye out for a couple of days ull notice too
Not all sports cars will come with them, in fact, it's usually the cheap imitation sports cars like sporty hatchbacks...Mazdas, Mitsubishis etc.
Lol @ ufo i've been watching countless documentaries on them and on ancient aliens/technologies. Not convinced but I love watching that shit along with any archaeology spec docos
Are we alone? Who knows? Probably not, but don't think I'll meet an Alien in my lifetime. Interesting stuff none the less.
I-Want-To-Believe-the-Alien-Version_4733-l.jpg?v=4733
Birdmang from this:
to this:
thoughts? (new fender + headlight that is) fair bit less weight which is a nice bonus just need to put rear fender eliminator on and my new DR-Z swing arm stickers :D oh and get some smaller indicators and red rim tape :P
you know i'll do special price for you on the LMs, so let me know if you want to test fit them or whatever
come past tullamarine on sunday?
ajay and neni are coming to check out the car. bring an LM :) lol
does anyone have a torque wrench I can use for 2 secs? just need to tighten my forks up again to spec.. my one only goes up to 20nm I need one that goes up to 30nm.. could be paranoid but don't want my forks breaking while riding :P
Birdmang from this:
to this:
Looking good, front fender looks much better. Meant to reply to your other post and say if you need a hand I'm only free after 7:30ish...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
