lol how could one not know what tony does..
new gt hrmm.. bet they'll slap a price increase for simply doing what they should have done at the beginning
http://theage.drive.com.au/motor-news/coming-soon-faster-ford-falcon-gt-20120628-214ow.html
My body is ready.
Depends where you go & whats in it. H&R block or your local accountant would be ~$100. Your specialised Tax Account in the CBD would be any from $200-$500+.
Edit: If you want me to do your tax, send me a PM, I'm doing it for a few guys on Wastelands at a lower price.
Cool thanks, i'll PM you later
I'm not in the wasteland that much, only come in once in a while
Depends if I have ti play soccer for the 1s or 2s. Either around 4 or 6
Ok cool!
I may!
lol not sure ill be able to this weekend though, and if i cant he will be in HK for the next 3 weeks :/
I see, will when you do get the R35 GTR around PM me :)
Good to get some pics too LOL!
Add your incomes together and then work out tax on the total; number of jobs is irrelevant. The misconception that you pay more tax on the second job is because you can only declare the tax free threshold with one of your jobs. What matters is total income, what bracket that puts you in, and tax withheld already.
/tonysapprentice
Hey Tony,
This year I had 2 Jobs, what rate does the 2nd job get taxed at if it was around $20k
/tonysapprentice
Correcto
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
