Never lubed my chain...how often should it be done?
500km is a good interval I think.
I wash my bike frequently so I clean and lube it after every couple of washes.
Some people put a little lube on before each ride. Besides the chain fling, I can't see the harm in doing this.
Fair call, they were always about the look rather than the drive lol. Hopefully new one is a better drive.
Yeh don't get me wrong they looked great but simple things like the seatbelt holder would constantly fall through the seats. Door jams wouldnt line up. Knocking and creaking sounds all over the joint uneven stitching in the interior I could keep going...
Even flat spots in acceleration. Man dissapointed in that car to the max.
The new one should be an improvement as anything would be an improvement
Too scared to wash my bike
Last time I washed it didn't start for days
f**k that shit lol
Just clean the fairings, that's all you really need to make it look clean.
Or get a newer model :P I pretty well flood my bike with water and leave it for a couple of hours to dry; starts first time everytime!
It's very highly rated from watching reviews on YouTube from USA. Never know though until ya get in one for yourself though
I guarantee the car will be completely different from USA to aus.. Firstly the tune will be different for the different emissions. Secondly a completely different interior. I wouldnt base assumptions on what's overseas.
/passionatehate4chrysler
Edited by Sunkist
Better get on it then, think I've done around 2000kms since I bought it. I could walk 10 meters and go check but I won't.
I've only washed it 3 times since I bought it too.. but I don't ride in the rain so it stays pretty clean anyway.
How do you do the chain? just spray it on wherever the chain is exposed and go for a ride or?
Best way is to have the bike on a stand, and spin the rear tire while constantly spraying on a sprocket (front or rear)
The other 'lazy' way which is what I usually do is just spray it where you can, move it forward a bit - spray a bit more and then go for a ride.
Less gangster more conservative which I think is better the interior is impressive from what I've seen, Unfortunatly Leigh ford interior is like one specification for 60k+ doesn't cut it imo
Chrysler/jeep under fiat are killing it grand Cherokee got car of the year i think?
While I agree it's not the best, when you get it optioned up (leather, colour screen, premo sound etc.) it improves the quality quite a bit.
Can't argue with ~400rwkw with a tune though :P
http://wardsauto.com...ngines-ceremony
SRT looks pretty gangster though :
17l / 100 k's in city apparently
Definitely get on it. It's mostly about lengthening the life of your chain and sprockets (and not having it overheat and snap on you), but it does make the bike ride quieter and smoother to ride too.
I usually spray it on the exposed part of the chain, wheel the bike forward a bit, spray again and repeat. There are little O-rings on each link that just going for a ride won't work the lube into, so it's good to spray the whole thing. Afterwards, either leave for a while to soak in / drip off, or you can wipe excess lube off with scot towels to reduce chain fling.
If your chain is particularly dirty looking you can degrease / kerosene it first, just be careful not to get this shit on your tyres and to wash it off with water, before putting the lube on.
You may notice it easier to wheel the bike after lubing; a good sign it was in need of one.
It's all same spec brah it's the 3.6ltr pentaster which is in the jeeps with a zf 8 speed interior specs are unchanged just model names are slightly different. Aus spec is slightly more inclusions I think as standard
It's same as e class merc chassis Or very similar I read same as jeep is ml chassis
And agree Leigh motor in ford is un matched
/chryslerfanboy
Edited by alr33x
Depends what you want really, that extra speed / supercharger sound or better interior - both cars look great the SRT obviously a bit rarer but that's not always a good thing either.
Just test drive them all
/chryslerfanboy
The old ones are the same as the e class but since Daimler ditched em I don't think they'll be using the same chassis. Not sure though..
I'll be interested in a test drive though to see the difference. I really fkn hated the old 300c
i usually just wipe it down without using water don't think i can make it any cleaner than it is now anyway
lol yeah it's old i've put it up for sale most likely going cbr600rr once/if it's sold
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
