still got your GTT stockies?
mind if i borrow them for a bit till my BBS' arrive?
thanks <3
yes you can, but the tyres are quite worn on those wheels, in fact, quite worn is an understatement.
I hope you are not planning on putting r34 gtt stockies on the r32....they will not clear the fronts...
Douchebag
lol. never knew that.
the hella ones? havnt gotten them yet.
they are the ones i bought. the ones in the car are stock and one of them sounds like there stones in it.
ah okay, was confused thought you meant the hella ones weren't loud :D
job interview tomorrow at ADT, wish me luck boys <3
good luck man :D
anyone know if there are any places which sell defi gauges in Melbourne? or at worst in Aus?
trying to grab an oil press gauge (no overnight parts from japan yo)
good luck man :D
cheers.. going crazy jobless atm!
My cousin owns a online parts store i'll see if he can get them.. I know there was talk of him beginning to stock them but thought most people were too cheap to buy them :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
