My best mate in high school (mates for like 6+ years), called his house once, his mum answered...I say Hi can I speak to Josh please......Yep who's calling?
'It's Michael'
'Just a second'
In the background "Josh phone...It's Michael....Who's Michael?'
'Dez'
'IS HIS NAME MICHAEL?'
Then another time his grandma wouldn't believe my name was Michael until I showed her my license...
How much and where from?
Also have that problem with my first name and people who've known me for years. On the other hand, I have to produce my licence for new people who don't believe my last name.
http://item.mobileweb.ebay.com.au/viewitem?itemId=120944113787&index=1&nav=SEARCH&nid=95945770549
Don't think you can get it locally. So worth it though, not gonna use anything else from now on.
http://item.mobilewe...nid=95945770549
I buy most shit off ebay anyway
I hope this isnt your car... Like a civic needs gold passivated cross drilled slotted rotors... and assuming from the USA markings they dba's?
Slotted rda's are more than plenty and cheaper too :)
Lol inb4 cracked rotors..
Almost as useful as Trd optioned brakes on 86 lol
Indians named Aaron Christopher Francis....It's like Asians named Gary.....or Toby...
Sounds like a serial killers name, is that what you are?
I'm not Indian you f**k.
Could be a serial killer. My dad and one of his brothers used to friends with a serial killer back in Sri Lanka. Obviously didn't know until he was in jail..
Not mine, and they're PasswordJDM ones. Just look awesome. Haha. its not on some standard civic either.
edit, they were like $110 +$80 shipping. only a few $$ more than RDA ones pickup from some places
If I was to do it IDE upgrade to 5 stud and benefit from a larger rotor
1st gen type R brakes (4x100) were the same size as the 2nd gen 5x114.3 (F282 R262). Would not understand why you'd need more on a ~1ton car.
I'd just keep it 4lug and put on type r sized rotors with type r calipers and good pads. spoon 4pots up front if it was a serious track car.
5x114.3 rims in 15-16" are a bitch to find as well.
saving for an engine swap now, not going to spend, srs
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
