for the past year or so my eyes have been hurting heaps.
last 3 weeks its gotten to the point where i sometimes wear sunnies in the office.
my eyes dont like the light.
going docs tonight. better not be going blind lol
kgo sau doctors.
Aaron was doing 1:38's sliding around at corner 4 and last corner before the straights
lol yeh when i was sliding around i was doing 1.38s and they werent the only corners.. i was doing where alvin was aswell
Edited by Sunkist
Chris with gtrrkt was doing 135 taking it really easy in the corners and flooring it in both of the straights.
Yeah I was just rolling through corners. Would love to see what the car could do flat out around Sandown.
Are you good at your job? Is there a high request for your role? Yes-no
Give me a pay rise dream boats or I'm out
Say you're on 'X' currently, and looking to further your career now looking for a little bit more 'Y' give them the vibe you're worth the extra and influence them / sell yourself
That's cuz Aaron is a sick kent
kgo sau doctors.
Pretty sure your turning into a vampire
Come to Sandown again on the 11th?
I was a flaggy when I needed some cash at a sandown day once was pretty easy 100 bucks lol sitting in a seat watching lexus / 35 GTRs etc i might come down and watch ya Toby
Martin I heard you were training my brother a bit down at PI :P
He blew a gasket I think.. silly unreliable RB25 :P
Haha I got that job now but now its 150. on call baby. free lunch too!!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
