Will have to organise another one some time down the track
Your house or Alvin's?
Cheers for the sausage sizzle and drink!
I'm not very good with faces so always need a reminder :/
Love you too brah
Why my house. Me got no wagyu
alvins.
I want a hit of this Wagyu he's been on about.
Totally mexican. Thats why when coilovers arrive, will need you to flare + roll those guards yo.
no worries.
let me do it before you lower the car though, its a pain when the car is too low and ill need to undo the bottom of the shock for it to work.
you and jono can come this saturday and ill do you both at once.
:3some:
Edited by Sunkist
alvins.
no worries.
:3some:
Be in baw baw this weekend.
Can i pay in wagyu? Lolol
Okay :(
how many guards do you want rolled and/or flared.
it all depends on how long it'll take.. but im not gonna sting you with a stupid price dude. wastelander special.
fronts just take longer because the caliper has to come off(or i prefer it to come off - more room)
Edited by Sunkist
Spent 70 ish on fuel. Will have a few hun tmr, but yeh. Fairly broke now.
Might have some coins somewhere in the car but those dont count
Lol and spent 400 on the whole wagyu lot, spent 270 on dinner on sat, spent lots this weekend
lol is $35 of that from the money I gave you lastnight? So when you pulled up you had $4 to your name?
lol
Looks like 98% of his income is directed at his appetite for waygu
LOL
$400 on beef?
are you of the retard?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
