I think you have to be an administrator to be able to give members' forum access to people, Ham.
Sounds like SAU Vic has started selling 86s haaaaah!
Yo look to the side when you're driving next time. Trying to wave to you on the Eastern last night, you prolly thought I was a cop in a white VE wagon lol.
Wtf that was you?!
The white ve Wagon was tailing me bad on the freeway, changing lanes when I did and quite close. Thought it was some bogans looking for trouble or someone I cut off or something haha
Was close to dropping back and getting behind the Wagon.
Paranoid much?
Go to another dealer
It was about a 12month wait via fleet
So buying it private should be shorter 6-12 months
Nah gg.
Toyota website says 18months too. People gone crazy for this car...
Interior was plastic and the dash reminded me of a hyundai Getz, I guess that's what you get for a budget car...
I'm used to the skyline interior design you can see a lot more money was spent but the car did cost more afterall.
Working on it! Weathers been shit so haven't been able to finish my polish :(
How long left in your probationary?
i see
still on L's dude
been too lazy gonna try booking for next weekend then i guess another 12 months of restrictions assuming i pass :/
yet to put L plates on my bike though lol f**k that
Wtf that was you?!
Paranoid much?
lol I went up alongside you and waved a couple of times, then resorted to pushing you off the road. Your peripheral vision sucks! Knew I'd have the cop look going on though, I'd have been para too.
yeah you do, but christian has told the admins that club execs are not to be mods, hence ash's hands are tied. i'm sure if he could ash would have at LEAST richo as a mod.
I didn't wanna say it, I think I've said enough
lol... dude the only person on the forum that thinks mad82 should be a mod is mad82. :rofl:
Gold isn't a light lol, it's just yellow!
Was considering gold levers but I think it's a bit much...they would really stand out and I'm going for a stealth look with minor gold touches. The shades of gold on different parts are also difficult to match; you can only really get away with small gold touches if the shades are different.
Lol Richo should be the moderator.
And lol
lol i see all. As the saying goes, if you dont swear once whilst driving, you are not paying attention.
Commodore tailing up behind me, then changing lanes, driving parallel and waving his arms then drop back behind and continues tailing.
Not sure if....shaking arms from a rage moment or a friendly wave haha
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
