Yeah bathrooms, seperate switches for heat lamps/light/fan all in the one unit...
Don't know how you'd get a tongue from the light to the switch without getting up there though? please explain.
Whatever you're about to explain might work on a house that wasn't wired up by f**king retards, which this place was...Made a simple job a headf**k and a half
i meant loop it with the light holder but you've got that 3 in 1 shiz still same thing though
do you want the e/fan and the unit fan to turn on/off together or the e/fan to have a seperate switch?
Nah I'm gonna go buy my V6 Live axle mustang tha'll rape a gt86 Straight line and on a track...and is cheaper..
seriously have you driven a USA stang?
I assumed it would handle like my xr6 ute, both 4L rwd live axle
damn was I surprised, the mustang is the worst car I have ever driven.
Think we're on a different page...Not sure what you mean by exhaust fan and unit fan....As far as I'm aware it's just got an exhaust fan... The one we installed in the main bathroom has 4 heatlamps that operate in groups of 2 with a switch per pair, a fan switch for the exhaust and a switch for the light
The ensuite one is the half size with 2 heat lamps on 1 switch, fan on another and light on another..
ah so you already have the exhaust fan installed and wanna put in the 3 in 1 unit?
thought was the other way round and you just wanted to add an extra exhaust fan...
No no...Neither bathroom had any exhaust fan at all....My dad wanted the heat lamps as well as exhaust fans in both, so my brother bought the martec units which had both in the one...
The fans themselves aren't as powerful as they need to be imo, so I might get 2 seperate ones and run the fan wires to those instead of to the 3 in 1 units....They'll still have the heat lamps and light in the main unit, but the stand alone exhaust fans will do a better job than the fan in the 3 in 1 can do... And at least I know for sure that it'll be a simple job, just loop it from the SDI running to the fan in the roof and hook it up to the stand alone exhaust fan so it'll still be operating off the same fan switch as the 3 in 1 was.
/electriciansaustralia
Wastland gurus, think I can get some frush look with spacers and no guard work? Not after huge aggressive stance, but just something that isn't as sunken as it currently is :S
Edited by kaitoukid
at minimum you'll need a guard roll.
maybe some 8mm spacers.. should sit nicely. I dont know why you'd bother though, its practical right now.. i'd leave it.
ah i see lol
well yeah that's what i was saying before then just loop it at the 3 in 1 unit and have both stand alone e/fan and the unit e/fan work together off the same switch. that's what we usually do anyway for people that want the 3 in 1 coz like you said the e/fan in the 3 in 1 unit is useless
8mm spacers and guard roll then, you think bro? haha so over practical (i'm sure there may come a time when i rue these words :P), you haven't seen the ride height! the box you can see in the reflection currently has my coilovers sitting in it! need free time and some tools so i can install them!
edit:
as you can see, dat gap! D:
Edited by kaitoukid
yeh im not a fan of slip on spacers though.. less wheel nut thread is dangerous.
i'de put the coilovers in, get some camber arms and get the thing aligned. if your still not happy then perhaps some bolt on spacers... even if you were to put extended lugs on there they are still weaker as the nut is further away still, more distance there is, a higher a chance you have of snapping studs..unless you go bolt ons, I wouldnt consider anything else.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
