lol solar never pays it self off. There is no storage in the system, only sell back when there is excess. and when the sun is shining during the morning/afternoon thats the lowest rate of payment. Electricity costs more at night and your solar panels arent doing much then.
There you go! and they go plenty fast, brembos stock too!
But can I bring myself into a fast ford with a slushbox?
I guess I'll have to find one to drive and see how I feel about that.
Feed in rate is 31 cents, which would be ~6 cents more than most people are paying per kWh to buy from their provider
No storage does hurt the effectiveness of the whole thing, but if you're feeding in an excess all day because you're not home and don't have anything running, then in theory as long as you use less at night than you fed in during the day, you'll be in front.
You're still buying from them for whatever you use at night, but at less than what you were getting feeding in during the day
my old man was saying something about a cap in terms of how many hours you can feed. I dont think its 6am - 6pm of constant feeding into the system? check the fine print or ask the sales person. There's something shifty about it which they dont speak of else my dad would have got a ready made kit instead of trying to build his own...
Yeah I don't know how it all works and how much a system is capable of feeding back in, but it says you're eligible for the tarrif as long as you have a 5kw or less system, and don't use more than 100,000kWh per year, which I don't think any house would even go close to (just assuming)
My parents went ahead and got it without researching too much, so I'm trying to find out all I can now to see if it's worth it or not, and hope there's a cooling off period (it's not installed yet)
lots of info here if you can be bothered reading it all
http://forums.whirlpool.net.au/forum/143
Good gearbox and a grownup car :P remember you can slap any turbo you like on it and the 4l will spool it with ease
Best part of all you don't get treated like a wanted criminal and insurance isn't a buttrape
I don't want to grow up at all!
I never had issues getting reamed by cops, it's just that insurance decided to rape me as their 'welcome back' present!
i went to qld last weekend, and when i got back on monday, there were panels on the roof. had no idea it was happening
Similar to my parents 'sept I didn't get to go to QLD...
What system did your olds get and how much? (PM if you want)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
