Put big enough wheels on it and cunts like Pettit will still pull you over.
good to see you calling petit what he really is... a cunt!
sick of hearing people say "oh he was actually really polite"
just because he gives you a reacharound doesn't change the fact that he just rammed a big blue dick up your ass
I've seen Birds from a distance once.. pretty sure he is some sort of half man, half bear, half pig.
i would have said half shark alligator half man...
curious as to whether anyone here will get that refernce without google....
possibly rik, but me thinks he may be too gay westcoast
