Do like the r6 or r1 probably depends which is a better deal considering I wouldn't be riding on it's limits if I decide to go down that path anyway.
Just hate the r1 stock mufflers lol
If it's not about limits, I'd still be going the R1...all that extra torque around town for not much difference in price. You'll ditch the mufflers for Yoshis/Akras anyway. The only thing the R6 really has on it is better fuel economy and probably friendlier to the inexperienced when ridden on its limits.
Mate is in Japan for work...Tells me he's enjoying the food
So, where's good for Japanese here? We'll hit it up when he gets back
Tookaiya - Keilor Rd. Been going there regularly for 7-8 years.
I've been to places like Nobu, Koko etc etc... And they are really good as well... However for the price, you will not find better that Tookaiya as it's not a fancy joint, just good quality traditional style. Massive thumbs up.
hmm worth a try one of these days.
then again, looking at the menu, i'm suddenly not interested anymore. LOL.
Edited by xALmoN
there's lots of japanese cuisine.
it really depends on what you want to have. for sushi though, you can't go past suzuran @ camberwell, although they're takeaway only.
And then there are the izakaya sake bar style places where its kinda like a japanese style tapas place, and for that, i recommend maedaya.
And there's teppanyaki, which is pretty much a scam (LOL), i used to be a teppanyaki chef @ fuji teppanyaki, and tbh, dont go there, or any other teppanyaki restaurant for that matter.
And for hot food, you could try ash's recommendation, in fact, i will eventually go there to check it out, but i'm in no hurry.
Rode in my mates 360kw xr6 and then I jumped into a mate's 200kw EVO 8.
Xr6 was crazy quick, its a three speed trimatic and pretty much fried tyres in every gear. Quick but felt sluggish. EVO felt faster lol, is it the weight and torque?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
