oh god dont get me started on that rspec.. looks terrible in real life
I'd still rather my GS and 20k to spend on it
Surely itd come in different colours right? But 20k more than yours? Fk that
why is it you always have pic fails, can't see shit
well it is made in Broady
lol motherf**ker, its one of those look at all the f**ks i give pics
FPV in campbo is for lease, well the building is...
aaron, built by dual syrian lebanese alliance. designed by some asian. possibly alvin.
Its probably duck taped on.
Inb4 cracks
the ford only comes in the colour scheme and the stripe packe is one they took off the new mustang then put on a much longer car and put a rspec sticker on it..
worst effort ever.
and they wonder why less ppl buy them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
