As discussed you'd need to be big to pull it off, and because I'm built like a bitch a no no for me :P
Just had rare as f**k steak cbf waiting for it to cook more
rare on this scale tasted good though
lol well done - waste of a good qaulity steak..
fixed my dash made a custom surround with scott..
So now you'll be attending meets?
Bitch...
P.S. paint it black Aaron.
yeh ill be at garage cafe soon. wait for me yeh?
i was driving to scotts house holding the dash lol
Yo how come my Rode NT3 needs less trim than my Shure Beta 87A...both on phantom power...
different mic's dude. lol
the nt3 is a condenser mic it'll be less sensetive and need less trim than the 87A. plus phantom power is shite lol.. when you turn it on though does it buzz?
we use condensers for high hats or border line snare. plus guitars brass etc for when there isnt a DI or an acoustic is being used without a DI
No buzz from phantom power, sounds really good actually! 87A is incredible, doesn't even sound like a mic...just sounds like someone's voice coming straight through the speaker. And that's using my guitar amp as a monitor lol.
well it means that the mixer is earthed really well then so thats good.
yeh 87a is a great mic. you should invest in either foldbacks or some studio monitors.. did you end up getting them? cant be mixing through comp speakers lol play the track on your theatre system and itll sound aids.
lol reverb level: karaoke. Gotta work out how to put on reverb first; this mixer has so much shit to learn.
Will be getting monitors when tax return arrives. What did you recommend again?
it has in built effects in the mixer doesnt it?
i cant remember what mark thought, but i was thinking Behringer B3031A
DUDE, if you can get your hands on a set of yamaha ns10 studio monitors, that what we use. its also what tupac used and 808 studios currently use still.
but they are exxy
http://www.ebay.com.au/itm/YAMAHA-NS10M-STUDIO-MONITORS-/150879125911?pt=AU_hifi_system&hash=item232118c197#ht_500wt_1203
they arent powered either so you need another amp
but they are exxy
http://www.ebay.com....7#ht_500wt_1203
LOL @ ns10's in 2012
they were good (and industry standard) like 20 years ago man...
there is a lot better out there these days.
if you want a reccomendation give me a price range and i'll ask my brother (he was the audio project manager for the olympic opening/closing ceremony)
Dude ns10's are still one of the top studio monitors, if they are powered with a correct amp.
Live is very much different to studio work.
Yes i work in audio, and we have quite a succesful company in live & studio work. Birds can confirm this.
We use ns10m and im pretty sure if out mixes came out shit we wouldnt be where we are.
Anyone who says ns10m are outdated and shit, cannot mix for shit. And thats why they believe they sound like shit
lol i realise studio and live are different... i'm sure andrew didn't fill the stadium with 11ty billion reference monitors ;)
that's only 1 area of his job lol - poor kid gets worked to the BONE for like $75k (problem is he loves it)
Remember I was a dj/nightclub promoer and involved in studio production for a decade and have toured pretty much every major dance music producer (well the pre 05ish ones anyway) and eveyone has been phazing out ns10's since the early 2000's. we had 2 sets in our studio, and moved 1 set into the loungeroom. there is still 1 set in the studio that gets used for production, but not the final mixdown
ns10's are good reference monitors for production no doubt, but the reason for them being where they were in the industry was moreso that they dont have the best sound, and if your music sounds good on ns10's then it will sound good on anything.
if you want reference monitors for listening, then there are better options is what i'm saying.
you should hear these new ones that andrew bought man.... somewhere in ther region of 5k... they sound amazing
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
