Ahhh welcome to the wasteland. Have to have another cruise soon when the weather is a bit more promising.
He was killed in the truck or by a truck?
Yeah not great weather for cruising, we should do Kinglake and surrounds sometime?
He was driving a truck and left the road.
Some good routes up there, I'd be up for it. However, of recent it's a known hotspot for the popo / yellow sticker people...so the more modified of us might not be so keen. Will have a chat with Tony and see what we can do.
Sad shit that, that you can be minding your own business without a worry in the world and in the next 10 seconds you're dead through no actions of your own.
These are the thoughts that bikelinesaustralia put up with everytime we ride.
That's what I said! Truck driver probably won't get anything either
So sad
Current brake set up is F242/Rdrums right. Should me buy brakes from vtec that are F262/R239 that'll be $500. Or wait out for Type R F282/R262 that will be 5lug (means have to buy new wheels/tyres) and would cost $1k for the brakes alone.
I wont be tracking this thing as of yet, but it'll be nice to get rid of the drums. Do some deca's ect.
Leaning towards the F262/R239 4x100. Which I can go pick up right nao.
take a lesson from all the old skyline owners here. Dont spend money on parts you dont need, Get out on the track/deca first and then decide what needs to be done.
Everyone falls into the trap of building track cars for a hypothetical track day sometime in the future.
Get out there now, find the limits with current setup, then replace to push the limit further.
So sad
if it was human error / fatigue i say put him away for 40 years cos that shits f**ked - shouldn't be able to wipe someone out and get away with it
This man, he knows.
Speaking of, Yoshi rearsets installed...darkness is spreading!
Can't wait for Pazzos to arrive :D
is it so hard to step 2 feet back then take the pic? :angry:
looks good. cover that bottle with something black so it's hidden
epic decision i made not to take out the bike today coz as soon as i got out of the driveway in the hilux it started hailing like a mafkr
Yup have a few guys asking when the next one is.
Will have to do one again, unfortunately got Winton & Haunted Hills coming up over the next 2 months, so just getting my car prepped for that.
But yes $2 Midnight Cheese and bacon rolls.
Haha I knew you'd say that...almost done.
Good call on the weather...deceiving shit.
can't wait til i am in le position in which i can afford both my car and a bike!
meanwhile in my current situation... coilpacks so expensive fffuu :P
You never win, when you are in le position there will always be more expensive things to get.
My r32 was better off when I was a student on casual wages. Now its all about budgeting & being serious with money :(
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
