VII.9 :yes:
The VII is a bit unloved, as the body styling is plain when compared to the VI and VIII.
VII are cheap, why would you bother with a VI with flogged bushes and gearbox.
inb4 Richo buys one for Time Attack
According to Wiki:
R32 GTR - 1,430kg
R33 GTR - 1,550kg
R34 GTR - ?
Evo 6 - 1,260–1,360 kg
Evo 7 - 1,320–1,400 kg
Evo 8 - 1,320–1,410 kg
Evo 9 - 1,310–1,490 kg
Add 18" wheels/tyres, exhausts, bigger brakes (a common GTR upgrade where EVO doesn't) and so on and it can certainly get higher :)
I suspect a R33 is heavier than 1550 to start off with. My GTS-R was 1400kg without me in it as i weighed it, and the GTR feels a LOT heavier than 150kg more. I remember driving Snowys R34 years back and it felt like at least 250-300kgs packed into it as it was similar from driving a EVO6 to a R33 GTR feels about the same in terms of difference.
Plus half the time the figures are not 100% accurate from a manufacturer as they dont say if its kerb weight (full fluids) or not.
A 6 and a 33R similar weight? No chance .. ive driven both and the 6 feels much lighter, even though the 33 R ha more power.
Maybe a 7 might be nearing the weight of a 33r but I doubt it
Seems about right
I can confirm this for you, my GTR is a 1999 R34, i have coilovers and a exhaust on it with a set of NUR spec NTo3+M rims, and i had to weigh it for blue slip, it came it at 1640KG with a 3/4 tank of fuel.
With next to no fuel,...
Eastern Ck weigh station (if accurate)...
V-Spec N1 = 1528Kg
Tony, nah cos no mention of N1 turbs, PFC and I don't see Brembos from the pics.
Different coilovers and 30,000-ish km has 'disappeared' there's paint fade on the roof that I don't recall seeing when its in my ownership.
Lol Aaron what you smoking brah
Don't think anyone said the 6 and the 33R were similar weight :P
what it sounds like? lol i've read it three times and sounds the same.. maybe my mind is f**ked today
