they dont touch me wagyu.
i dont have any now anyway.
i'm not fussed about them drinking it, its the fact that, when i go to the fridge for a can of coke, i find there's nothing left. no bloody initiative to replace the stuff they finish too. house meeting tonight, i love those sessions!
Lol crack the shits Alvin!
Who is actually head of the house?
Do people actually listen in these meetings?
I can imagine you saying all this stuff, but in their heads its like 'blah blah blah'
they will do what i want to shut me up, and start their nonsense again after awhile. and apparently it does work. one retard used to hoard all the bowls in his room. by hoard, i mean, unwashed plates and bowls were all in his room, he just kept using clean ones till there wasnt anything left in the cabinet. I cracked the shits once, he now washes them more promptly.
though he's a little slower on the uptake with regards to metal spoons and nonstick pans.
but as long as they replace my shit, problem solved.
and nobody is actually head of the house, but since i'm the only that actually does any real cleaning up, i feel i have the right to crack the shits. right?
Edited by xALmoN
Alvin: " hey you dik hed stop dlinkin my cok I wee kirr yuu"
Jason: "I ha' da flend who ha' da fellalli belly quik yu no"
What cop attention?
I never heard of it.
It's a knox thing.
Every time I booted the GTR I wait for 10 seconds after.. did i get pulled over? no? f**kyeah.
Alvin do you own forks? next time i'll BYO:p
It's a knox thing.
AHAHAHAAHAHAA. I do have forks. dw. next sesh isn't a chopstix sesh anyway.
Thank god! nah I'm not THAT bad with them it just requires far more effort and eventually I just cbf eating :P
Hahahahahhahahaha. I can imagine you getting pissed off at your food and eventually stabbing it with a chopstick
Yeh the horn. It's a 2 tone air horn. 140db measured 5 meters away. Fkn things made me deaf a few times..
See I want traction man, I don't have it until (sometimes) third and fourth, by then I'm going to fast to even use it on the street, let alone be able to put the first few gears down on a track
So you're buying a GTR next?
:D
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
