they dont touch me wagyu.
i dont have any now anyway.
i'm not fussed about them drinking it, its the fact that, when i go to the fridge for a can of coke, i find there's nothing left. no bloody initiative to replace the stuff they finish too. house meeting tonight, i love those sessions!
Lol crack the shits Alvin!
Who is actually head of the house?
Do people actually listen in these meetings?
I can imagine you saying all this stuff, but in their heads its like 'blah blah blah'
they will do what i want to shut me up, and start their nonsense again after awhile. and apparently it does work. one retard used to hoard all the bowls in his room. by hoard, i mean, unwashed plates and bowls were all in his room, he just kept using clean ones till there wasnt anything left in the cabinet. I cracked the shits once, he now washes them more promptly.
though he's a little slower on the uptake with regards to metal spoons and nonstick pans.
but as long as they replace my shit, problem solved.
and nobody is actually head of the house, but since i'm the only that actually does any real cleaning up, i feel i have the right to crack the shits. right?
Edited by xALmoN
Alvin: " hey you dik hed stop dlinkin my cok I wee kirr yuu"
Jason: "I ha' da flend who ha' da fellalli belly quik yu no"
What cop attention?
I never heard of it.
It's a knox thing.
Every time I booted the GTR I wait for 10 seconds after.. did i get pulled over? no? f**kyeah.
Alvin do you own forks? next time i'll BYO:p
It's a knox thing.
AHAHAHAAHAHAA. I do have forks. dw. next sesh isn't a chopstix sesh anyway.
Thank god! nah I'm not THAT bad with them it just requires far more effort and eventually I just cbf eating :P
Hahahahahhahahaha. I can imagine you getting pissed off at your food and eventually stabbing it with a chopstick
Yeh the horn. It's a 2 tone air horn. 140db measured 5 meters away. Fkn things made me deaf a few times..
See I want traction man, I don't have it until (sometimes) third and fourth, by then I'm going to fast to even use it on the street, let alone be able to put the first few gears down on a track
So you're buying a GTR next?
:D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
