the engine number is stamped on the turbo side on the bell housing flange you cant miss it, it says SR20 and then a bit lower it will have the number.
Do I have to get under the car? Or will I see it from the top. Remember I have a big f**k off turbo in the way
lol who tagged you?
car never single pegs lol
no idea, heaps of ppl were tagged lol
was on nis's wall tho
AME TM-02s
19x9.5 +22 might be pushing it for the ol falcon tho :\ only come in that and 10.5 in 19s
Do they have more tyres in stock or just what's advertised on eBay?
No 17" nittos listed on ebay
will be some coming in nek week, that's what i was told. or rather. i was told there'd be 245 R17s coming in nek week.
yup. i am. seems to be the most cost effective semi decent tyres without having to go to tyrerack.
KU31 ftw; will be plenty for standard power.
Will be offloading my 265/35/18 KU31s for cheap soon. ~70% tread
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
