Has anyone watched The Raid Redemption?....Sick movie!
http://www.imdb.com/title/tt1899353/
Seen it. Can't say I liked it as much as other guys.
The new Judge Dredd movie seems to be a similar style to this judging by the trailer
ah nice they'd go down pretty fkn sweet with some good scotch
need to find some cohibas for new years eve
They stock cohibas as well, they pretty much stock everything
www.bestcigarprices.com
Just make sure if you have stuff ordered they clearly label the weight of cigars only as thats what the duty is calculated from and it ain't cheap at $436 each kg
fitted my focus RS insert today!
Already looks heaps better every with tape still on :P
Last time i smoked a cigar i forgot it was a cigar and inhaled it, then coughed my guts out for the next 20 minutes.
typical arab, probably thinking of shisha while you doing it
no... the money i save in hospital bills will easily outweigh your petrol savings
Private health insurance ftw
Well I just saw this on the Herald Sun...
http://www.heraldsun.com.au/news/national/motorcyclist-wills-high-speed-crash-into-a-trucks-trailer-in-south-carolina-caught-on-film/story-fndo48ca-1226474174054
I know it's his human nature / reaction to a traumatic event, but it's pretty retarded to say you're not getting back on a bike because you're a husband/father etc. after you have an accident. Did he think he was an invincible husband/father beforehand? Since when have motorbikes not been life threatening? I wouldn't ride one if I had kids.
False.
There is no aerospace design industry in Australia. There is Boeing in pt melb but that is just a manufacturing wing. Designs come from America.
Apply for mech jobs and hr will knock you back as they want mech eng not aerospace.
Have couple friends who did aerospace. Had a real hard time finding jobs.
Was about to say same thing mates sister couldn't find anything at all
U gonna be rich
If I can get a job... ! LOL :(
False.
Haha yes, this.
Dunno about getting knocked back from mech jobs though (granted I haven't applied for grad positions, still got 2.5yrs left since double).
Most people from companies I have talked to have told me that while obviously it is/can be a factor, they're not too fussed; and it's more the person themselves. Of course when it really comes down to grad positions, will have to see (as apparently your mates have gotten knocked back, gg). But yeah, I was talking to Holden purchasing program manager, and he's a chemical engineer by trade iirc.
He gonna be at NASA brah
Yeah monies overseas unfortunately.
Luckily for me I actually don't mind / would like to head overseas :D.
Maybe I should double major in another language... like german... hmm...
OT
Damn only a broken wrist and leg :O
Edited by kaitoukid
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
