look for teh adam's apple,
also take note of the height of average girls, and the ex men..
and before they say "want a blow job" in a manly deep voice. gtfo.
though the adam's apple can be surgically rectified, and so can the voice. look for manly frame, and manly hips. and they're usually tall too. for some reason, all the trannies encounter, have been pretty tall for an azn, like my height or taller.
ah, and trust your innate heterosexual instincts..
I think I will jsut avoid all of them
and sit in my room with a bottle of scotch
scotch rocks or ice? thoughts?
i drink neat. 99% of the time - (sometimes in summer some rocks are nice tho)
if you are going to dilute it i'd go ice.
a little water in scotch opens up some of the lighter floral notes, which would not happen with the rocks.
So birds sent me the pic of what got him banned. Doesnt make sense. Technically the Orpheus is covered and therefore ok to be posted.
hey officer is that an orpheus!??
lol, my mate took my wheels and tyres to get fitted an balanced.
apprentice comes to fit them, boss walks out of his office and just yells NO ILL DO THEM.
then he went on for the next 15 mins about how pricey these things are, proceeded to fit them etc with great care and didnt leave a single mark.
will be using this place again for a long time to come!!
whilst this is true... i dont think i'd want it on my screen @ nab
you coming nationals?
^ this is generally the reason why.
If it was in a NSFW thread, then yeah ok bit different - but either way it's pretty obvious to be right on the limit.
Brings the ole "if you think it might not be right, it probably is". So just don't :)
Nah... think i might go check out the birth of my son instead...
f**k nab. The f**king shit hole of a place. I don't know how your still putting up with senior management.
easy man... I dont have to deal with management past the LSC ops manager.
4th person want to try for a ban this week?
Stop posting images that are unacceptable. It's so simple that 75,000 other people can get it right day in, day out - hard to comprehend why 3 of you so far cannot.
So don't piss/moan/argue/push boundaries - just don't do it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
