Who is good with wiring and shit? Cluster and window switches died on me yesterday, some chewed wires in wheel arch loom (dat stance) but I joined them together again with no success. All fuses under dash and in engine bay are sweet. Help plz
You should probably check those wire properly and make sure they haven't broken elsewhere/are now contacting properly.
I rubbed through some of my loom and lost my cluster, windows etc.
They only appear to be broken in the one spot, the rest of it seems fairly well insulated. Was it just that bit of the loom that was your problem?
Yep was only the loom, took a spur of the moment late night trip down the GOR. Cluster and electrics died and kept driving, then the car died and wouldn't start back up, ended up getting the car towed to local racv blokes shop and staying in Appollo Bay courtesy of racv. Walked to the shop next morning, taped everything up nicely, tucked the loom and drove home.
With those km I wouldn't pay more than 8k for it.
Yeah I'd always be offering 1k less and never pay list price, it's expected lol
rather pay $10k for this
http://www.bikesales...3624E8&__Nne=15
Too old brah something about riding around on an older bike would make me feel weird / paranoid something will fail when doing 110+
Can't just be me?
Bit more for one of these!
http://www.bikesales.com.au/private/details/ducati-848-2008-12920871?__N=1432%20604%201430%201429%201626%201428%204294967242%204294966239%2082&__Ns=p_PriceSort_Decimal%7c0%7c%7cp_Make_String%7c0%7c%7cp_Model_String%7c0&__Qpb=1&__sid=139F477975AA&__Nne=15
birds have you got full comp on bike? thinking next bike will be well under 10 again and i'll just get third party again (thankfully i had it last time).. cbf paying 2 full comps / full regos
Lol hardtuned meet. Everyone said there were no cop issues, everyone was behaving. So I decided to go. It was really good...
... For 5 minutes.
Then the launch control contest began, and who can do a skid the best. People were actually doing skids, leaving, coming back, and doing more skids..
What a fail.
/csb
... For 5 minutes.
What a fail.
/csb
heard a few peeps got defected. Any confirmation mah nigguh?
Don't think so, it was only a divy Van that rocked up and told people to leave.. I went back in the missus car hoping to see someone face plant a wall, but it was literally emptied.. So I doubt that anyone got defected.. There was a chaser that did at least 6 laps of burnouts lol
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
